Download zu Niedrig .... Hilfe ?? https://forum.kabel-helpdesk.de/viewtopic.php?f=24&t=5868 |
Seite 1 von 1 |
Autor: | Tobi1204 [ Sa 30. Aug 2014, 18:28 ] |
Betreff des Beitrags: | Download zu Niedrig .... Hilfe ?? |
Channel 1: Channel ID: 83 Downstream Frequency: 666000000 Hz Modulation: 256 QAM Power Level: -3.0 dBmV Signal to Noise Ratio: 36.2 dB Channel 2: Channel ID: 77 Downstream Frequency: 618000000 Hz Modulation: 256 QAM Power Level: -4.8 dBmV Signal to Noise Ratio: 35.6 dB Channel 3: Channel ID: 78 Downstream Frequency: 626000000 Hz Modulation: 256 QAM Power Level: -4.2 dBmV Signal to Noise Ratio: 35.6 dB Channel 4: Channel ID: 79 Downstream Frequency: 634000000 Hz Modulation: 256 QAM Power Level: -4.0 dBmV Signal to Noise Ratio: 36.0 dB Channel 5: Channel ID: 80 Downstream Frequency: 642000000 Hz Modulation: 256 QAM Power Level: -3.6 dBmV Signal to Noise Ratio: 35.9 dB Channel 6: Channel ID: 81 Downstream Frequency: 650000000 Hz Modulation: 256 QAM Power Level: -3.0 dBmV Signal to Noise Ratio: 36.0 dB Channel 7: Channel ID: 82 Downstream Frequency: 658000000 Hz Modulation: 256 QAM Power Level: -2.9 dBmV Signal to Noise Ratio: 36.2 dB Channel 8: Channel ID: 84 Downstream Frequency: 674000000 Hz Modulation: 256 QAM Power Level: -3.5 dBmV Signal to Noise Ratio: 36.2 dB Upstream Channels Channel1: Channel ID: 4 Upstream Frequency: 37400000 Hz Modulation: 16 QAM Bit Rate: 20480 kBits/sec Power Level: 46.0 dBmV Channel2: Channel ID: 1 Upstream Frequency: 58400000 Hz Modulation: 16 QAM Bit Rate: 20480 kBits/sec Power Level: 48.5 dBmV Channel3: Channel ID: 2 Upstream Frequency: 51800000 Hz Modulation: 16 QAM Bit Rate: 20480 kBits/sec Power Level: 46.0 dBmV Channel4: Channel ID: 3 Upstream Frequency: 45200000 Hz Modulation: 16 QAM Bit Rate: 20480 kBits/sec Power Level: 46.0 dBmV |
Autor: | Nutella [ So 31. Aug 2014, 08:57 ] |
Betreff des Beitrags: | Re: Download zu Niedrig .... Hilfe ?? |
Ok...Toll...Modemwerte wie ich vermute... Und was ist jetzt genau das Problem? Wieviel hast du gebucht, was bekommst du? Welches Betriebssystem nutzt du? Wie wird der Speedtest, und auch welcher, ausgeführt? (über Kabel, Wlan) Die wichtigsten Informationen für einen Fehlerbeschreibung sollte man von sich aus bereitstellen könne, sonst wirds mit dem Helfen schwer. Manuel |
Autor: | Tobi1204 [ Sa 6. Sep 2014, 13:16 ] |
Hab 50000 leitung von unity media und mein speedtest zeigt download : 256 kb an upload : 2,1 mb und alles über kabel betriebssystem ist win 7 |
Autor: | tonino85 [ Sa 6. Sep 2014, 13:26 ] |
Modemwerte? |
Autor: | tokon [ Sa 6. Sep 2014, 13:44 ] |
tonino85 hat geschrieben: Modemwerte? Die stehen doch im ersten Post ![]() Und sehen nicht so schlecht aus. |
Autor: | tonino85 [ Sa 6. Sep 2014, 13:47 ] |
Ah. Übersehen. Denke dann ist das Segment überlastet. |
Autor: | Tobi1204 [ Sa 6. Sep 2014, 14:56 ] |
Und was mach ich jetzt ??? Das problem hab ich seit 2 wochen |
