Fritzbox 6320 v2 Cable problemme https://forum.kabel-helpdesk.de/viewtopic.php?f=24&t=4161 |
Seite 1 von 1 |
Autor: | bogdice [ Fr 19. Apr 2013, 22:13 ] |
Betreff des Beitrags: | Fritzbox 6320 v2 Cable problemme |
Entschuldigen Sie mir, aber Ich kann nicht in Deutsche Sparche meine Problemme eklären... I have recently surscribed to Unitymedia and got a Fritzbox 6320 v2 Cable modem/router ... I just want to open some ports, tcp and udp, but it doesn't seem to work... I have tried to open in the menu -> Internet -> Freigaben but it doesn't work. There is also a section Ipv6 in the Freigaben menu, but I don't know what's my Interface-ID or if i should change something there... Can you please help me? Thanks! |
